Fórum kezdőlap » International area » 2013 Events
Új téma nyitása A témát lezárták, nem szerkesztheted a hozzászólásaid, és nem küldhetsz új hozzászólást.  [ 6 hozzászólás ]
 Hozzászólás Elküldve: szer. jan. 02, 2013 7:21 pm
Csatlakozott: csüt. jan. 19, 2012 1:05 pm
Hungarian RC trial Championship 2013
Description of the vehicles:
- Plastic, wooden or metal body only
- Full body needed, including doors, read and front bumpers, drop or faltbeds etc..
- Front windschield is required
- Closed body with doors (e.g. stock Pajero body). For roofless/open/cabrio vehicles full interior and roll cage are required (dash, seats, trasmission, side panels)
- All tires must be the same
- Only front wheel steering allowed
- Batteries must be attached to the chassis (axle or link mounts are not allowed)
- At least half of the wheel must be under the body (including fenders)
- DIG or any similar axle braking system is not allowed
- Ladder frame (e.g. Axial SCX) and Tamiya XC/CC/TA like chassis BOTH allowed, but
- Crawler and stick chassis are not allowed!
- One car per competitor allowed
- Minimal light system required (2 white LEDs at front and 2 red LEDs at rear)
- Minimal wheelbase: 242mm
- Minimal track width: 190mm (measured from the outer side of the tyres)
Suspension:
- 4 shocks required with vertical mount (+-20 deg. difference allowed only - no crawler style mounts!)
Tires, wheels:
- All 1.55 and 1.9 tires and wheels allowed, but
- Maximal tyre diameter is 116mm.
Drive:
- Single, electric motor allowed only (can be brushed or brushless)
- No battery size, voltage or capacity limitation (e.g. LiPo)
Winch and external tools
- Wich usage is for +5pt/connection, except free winch points
- External helping tools, carried by the vehicle, presented upon entry, is allowed (e.g. rope, ramps)
The race:
- Time has less importance than scale look and precisitiy.
- Starting points are 200.
- The scale point are deducts these at entry (max. 40pt).
- After the completed race, the collected faults are added.
- The less point are the better.
- Average gate width: 26cm
- Any tuch of a gate +15pt
- Hand tuch of the vehicle (e.g. manual roll over): +30pt
- All gates must be completed, at least tried to complete. Gate miss: +30pt
- Repair time during the event is maximum 1x5 minutes. (If the repair is not done under this time, the competitor will be disqualified)
- Starting order is drawn after the last entry.
- One driver can enter only one Class!
Missing mandatory scale accessiores: +10pt/item
Practice:
- Off-track local pactice is allowed, not disturbing the actual competitor.
Scale poins: ................................................stock.................home made
- Showel, jack, ropes, boxes etc. ……................ 1pt....................2pt
- Working doors ............................................ 3pt....................6pt
- Full interior.................................................. 2pt...................4pt
- Full engige room .......................................... 2pt....................4pt
- Leaf spring suspension.................................. 4pt.....................6pt
- Fake spare wheel..........................................1 pt...................2pt
- Real spare wheel.......................................................3pt
- Metal roof rack............................................ 2pt.....................4pt
- Plastic roof rack........................................................1pt
- Working winch .............................................3pt.....................6pt
- Fake winch...............................................................1pt
- Simple lights ................................................1pt.....................2pt
- Scale lights (turn signal, brake lights, etc)..........2pt....................4pt
- working windschield wiper................................2pt....................4pt
- sleeping bag, polifoam, hand tools.................................1pt
- scale driver...............................................................2pt
- Roll cage - external....................................................2pt
- Roll cage - internal.......................................metal 2 pt, plastic 1pt
- Sand ladder.................................................metal 2 pt, plastic 1pt
- Hidden body mounts ...................................................2pt
- Racecar reproduction (100%).......................................5 pt
- Scale tyre (smaller tyre, like on real cars, e.g.
mud trasher under Yota, tyre is under the body).............. 3pt
CLASS 1 rules
1. Full hard body (e.g. stock or modified Tamiya Pajero, Hilux etc. or handmade styrene bodies e.g. Leo's G Mercedes )
2. Front windshield and door windows
(if you dont have windows, the car must have full interior)
3. bumpers (front + rear)
4. 1 box
5. 1 tow rope
6. 1 jerry can
7. windshield wipers (fake)
8. first aid kit
9. scale license plate with country code (based on your contry regulations)
furthermore, waterproof electronics and winch are advised
CLASS 2 rules
differences from Class1:
1. lexan body (e.g. stock or modified Axial or Proline bodies)
Points are based on rankings on each event:
1st. place......20pt
2nd. place.....18pt
3rd. place......15pt
4th. place......12pt
5th. place......10pt
6th. place........8pt
7th. place........6pt
8th. place........4pt
9th. place........2pt
10th. place......1pt
 Hozzászólás Elküldve: kedd feb. 05, 2013 8:47 pm
Your questions and remarks are welcomed here :)
 Hozzászólás Elküldve: kedd feb. 12, 2013 9:41 pm
Csatlakozott: szer. jan. 09, 2013 11:02 pm
Thank you guys for the translation - sounds very cool and i think there would be no problem with the rules!
One question: How many sections are to drive on a event? And how long would be the drive time? Ok, that was 2 questions :mrgreen:
With best regards,
Gerry
RC4WD - Teamdriver
Team Stonerockers Austria
RCBM - Scaleparts Teamdriver
 Hozzászólás Elküldve: szer. feb. 13, 2013 12:14 pm
Hi Gerry!
Usually there are two stages on an event. The usual drive time is between 10-30 minutes on each stage, depending on the driver.
 Hozzászólás Elküldve: szer. feb. 13, 2013 1:59 pm
scale4x4 írta:
Hi Gerry!
Thanks for the info!
RC4WD - Teamdriver
 Hozzászólás Elküldve: hétf. feb. 25, 2013 3:18 pm
Updates are marked with red:
- Missing mandatory scale accessiores: +10pt/item
