Új téma nyitása Hozzászólás a témához  [ 83 hozzászólás ]  Oldal 1, 2, 3, 4, 5 ... 9  Következő
 Hozzászólás témája: ECX Barrage 1.9 ( 1:12 )
 Hozzászólás Elküldve: szomb. aug. 12, 2017 9:21 pm
Bevállaltam egy ilyen kis járgányt. Leginkább youtube videok alapján. Amolyan mágnes volt.
Hogy szép -e? Szerintem igen. :)
1.9 4WD Barrage Brushed: RTR
ECX-Barrage-1-9-4WD-Scaler-1-12-RTR-094ECX01009I_b_7.jpg [ 88.58 KiB | Megtekintve 33517 alkalommal. ]
What's in the box?
(1) 1.9 4WD Barrage
(1) 2.4GHz Transmitter
(1) 900mAh NiMH Battery
(1) Charger
(1) User Manual
Scale Body and Chassis
Completely Ready to Run: Everything needed is in the box
Waterproof electronics: Drive in any conditions
Licensed Falken AT3W All Terrain tires: Soft compound treaded tires provide superior grip over most surfaces
ECX 2.4GHz TX and RX/ESC: Interference free driving
900mah battery: Over 30 minutes of run time
One step charger: Plug in the battery and it charges automatically
4wd drive train: Extreme power for climbing
Metal ring and pinion gears: Durability and longevity
Locked differentials: No slip and true 4WD power
Multi-link suspension: Increased articulation and ability to scale most obstacles
Oil filled, coil over shocks: Adjustability and superior handling
Aluminum links, motor plate, wheel rings, and shock cap retainers: Durability and styling
Combination composite and aluminum main frame: High strength and durability
High torque motor: Maximum crawling power in small efficient package
Axle mounted steering servo: Weight down low to provide low CG
1/10 scale servo compatible: Can use readily available electronics
Advanced battery mount system: Adjustability for different conditions
Full ball bearings: Efficiency and increased run time
Super user friendly speeds with impressive crawling capabilities: Fun for anyone from beginner to expert
folyt köv :)
 Hozzászólás Elküldve: szomb. aug. 12, 2017 10:27 pm
- a Lindinger -től érkezett , a csomagba bedobtam még egy mini Warn csörlőt
Amit csináltam eddig rajta:
- shock limiterek eltávolítása
- a torony első bekötésnél kivettem a keresztmerevítőt h legyen szabadabb rugóút elöl
- servo csere ( a gyári spektrum egy vicc )
- felni volt itthon + vettem rá egy Axial Ripsaw -t
- került rá egy homokvas is persze
- a front bumper előrébb jött, a szárára 1-1 -ben fel lehetett csavarozni a csörlőt
- rendeltem hozzá egy 17mm széles hexet h a kocsi elérje a 210mm -t (adott esetben van egy 20mm -es hex szélesítő is)
- kormányművet kicsit megfaragtam, de a műanyag knuckle helyett fém kell, és akkor MÉG javulni fog a dolog ill egy fém kormányösszekötő is sokat fog rajta javítani
- az akku tálca hátrébb került
- az első kihajtás kapott egy zsugorcsövezést beázás ellen ( ill. állítólag szereti a CVD tüskét / pin -t elhagyni)
20771676_2317926871766453_2036366214_o - Copy_resize.jpg [ 195.68 KiB | Megtekintve 33515 alkalommal. ]
folyt. köv
A hozzászólást 2 alkalommal szerkesztették, utoljára laszieee csüt. aug. 17, 2017 9:17 pm-kor.
 Hozzászólás Elküldve: szomb. aug. 12, 2017 10:52 pm
20806663_2318992014993272_859968600_o - Copy_resize.jpg [ 209.68 KiB | Megtekintve 33513 alkalommal. ]
 Hozzászólás Elküldve: szomb. aug. 12, 2017 10:54 pm
20017764_2296168023942338_2422680186070698679_o - Copy.jpg [ 157.24 KiB | Megtekintve 33513 alkalommal. ]
19904938_2296146473944493_1893856696747813484_n - Copy.jpg [ 147.79 KiB | Megtekintve 33513 alkalommal. ]
 Hozzászólás Elküldve: szomb. aug. 12, 2017 11:04 pm
az ECX Barrage kocsi közös vázon fut a:
- FTX Outback
- HSP / RGT racing kocsikkal ... eltérés a szokásos (elektronika ill bódé)
Tuning cuccok EU -ban az FTX -vel kompatibilisek.
Ui. az ECX kihozta a Doomsday (Mad Max klón szerű) és a kit verziót - azok már a továbbfejleszett holmikkal vannak szerelve ...
ECX-Barrage-Kit-3.jpg [ 86.45 KiB | Megtekintve 33367 alkalommal. ]
Sok apró fejlésztés, de nem mind tűnik annyira értékesnek h egy kb 120 usd -s átépítést megérjen ... de ötletek jók vannak benne , hogy kicsit faragjunk a mostanin ezt azt ... :D
A hozzászólást 2 alkalommal szerkesztették, utoljára laszieee szer. aug. 30, 2017 5:54 am-kor.
 Hozzászólás Elküldve: vas. aug. 13, 2017 4:24 am
Szia!
Határozottan szeretem az unortodox építéseket, úgyhogy követem. :)
A vízhatlanítás nem az erősségem, ezért köszönettel veszem, ha lősz egy közeli képet az első kihajtás zsugorcsövezéséről.
köszönöm:
 Hozzászólás Elküldve: vas. aug. 13, 2017 4:33 pm
hát nem vízhatlan, de védeni sokat véd
(por stb ellen , bár hallottam már olyat h a hídat valaki "kitömte" fehér zsírral)
Ha jól sikerül a zsugorcsövezés, az szinte "rátapad" ahová kell ...
19390775_2276644845894656_6007705245838104164_o - Copy.jpg [ 156.91 KiB | Megtekintve 33506 alkalommal. ]
mint látható a gyári rövid kormánylink hossza nem jó ...
19222711_2276644852561322_5274192134747972277_o.jpg [ 184.87 KiB | Megtekintve 33506 alkalommal. ]
egyik irányba nem úgy kanyarodik ... azóta rövidebb lett a link, ill hosszabb a servo kar ... és máris jobb lett a kanyarodás is ... de utón vannak az update cuccok. Ha minden jól sül el, ismét jelentősen javul a kicsike ... :D
A hozzászólást 1 alkalommal szerkesztették, utoljára laszieee csüt. aug. 17, 2017 9:22 pm-kor.
 Hozzászólás Elküldve: vas. aug. 13, 2017 8:38 pm
Így már értem.
Köszönöm! :)
 Hozzászólás Elküldve: csüt. aug. 17, 2017 9:25 pm
ma az FB -s ECX topikban kaptam egy infót - miszerint a futómű cuccok kompatibilisek az ECX Temper Crawler -ével, és az upgrade cuccok 1-1 -ben jók a Barrage -ba is
(eme holmik könnyen felismerhetők a Temper alkatrészek klasszikus királykék színéről) ...
a HR ( hot racing) holmik szintén királykékek, és van belőlük több is ami a Barrage -hez is jó lehet
(vagy bármelyi FTX autóhoz)
Ui.: tuningolni nem olcsó, és érdemes vmi józan ész alapon nekikezdeni, mert attól még a kocsi nem lesz világverő, max. csak egy lehetséges klassz ellenfél :)
Ui.: és ... nem a színes alkatrészek nyerik meg a versenyt :)
Sikerült némi tartalék motyót szerezni több mint baráti áron: (jah ... a 4db shock rajta sincs a képen)
20841500_2320608354831638_1562014984_o - Copy.jpg [ 151.61 KiB | Megtekintve 33455 alkalommal. ]
 Hozzászólás Elküldve: szer. aug. 23, 2017 10:28 pm
Ez is jó kis Low-Cost autó, lassan szemeznem kell a fiamnak is valamit, már 5 éves. :)
Itt meg 4 évésen 500€-s autót adnak a kollégák a gyerkőcnek... :roll:
